Hi, got a problem with my iTunes. Whenever I plug in my iPod, it attempts to sync it but a error appears saying It can't copy, error -48.
Now, I know that it isnt the ipod because it worked fine on (dare I say it..) Windows. The first time i plugged it in my mac, this error showed up
If i click OK on the error, and then press Sync manually, it works? Just it won't sync automatically when I plug it in
Any Ideas?
.If i click OK on the error, and then press Sync manually, it works? Just it won't sync automatically when I plug it in
Any Ideas?
(I'm still on Tiger if that makes any difference?)
