iTunes 7.6 won't run
7 Mar 2005
LU7
Just installed iTunes 7.6 on to my XP install so I can see how it has changed and is it better with my iPod than Winamp's built in iPod plugin.
It installs fine but when I run iTunes using the desktop shortcut nothing visibly happens, iTunes.exe appears in the task list but nothing loads up.
I've tried most of the ideas on http://docs.info.apple.com/article.html?artnum=302856 but they don't work. So what is going wrong? I've removed Quicktime Alternative and restarted but still nothing.
I am in exactly the same boat!
If you google there is plenty of threads on this. I have tried so many of them but still no itune.
I now use winamp.
I had this when the GF bought a Nano. Ended up haveing to ( I say having to, Cus the woman wanted to use Itunes!!!) do a format and reinstall never worked out what the problem was.
Cheers guys. Just to make it clear I do use Winamp, just wanted to see what iTunes was like nowadays. :)
iTunes is Evil MmmmKay!!..
The mlipod plugin http://mlipod.sourceforge.net/ is much better than the built-in 9stripped down) winamp plugin!... theres a few more options, including coverflow (Album Art) which never worked for me with the built in plugin but does with mlipod!! :cool:
id reinstall itunes/quicktime after uninstalling the quicktime alternative personally
I worked that out. :) Installed iTunes/Quicktime then realised QT might have clashed with QA so off came QA and iTunes/QT back on again with a restart thrown in for good measure. Still nothing. :(
Ja ich weiss das. ;)
I used to religiously update the ml iPod plugin but since Winamp came with its own version I've found that suits for me. :)
