7 Sep 2008 at 04:04 #1 Twentymac Twentymac Associate Joined 2 Oct 2007 Posts 1,602 Location Birmingham Right i was wondering if anyone could help me out with Itunes. I have many different songs listed on my Itunes library but they come up as different albums.... An Example : It shows up in as different albums on my ipod aswell :S
7 Sep 2008 at 09:39 #2 Cannaton Cannaton Associate Joined 10 May 2004 Posts 1,084 Location Liverpool Have you tried checking that "Artist" and "Album Artist" are the same??
7 Sep 2008 at 09:44 #3 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,891 Location In the radio shack Firstly, click on the album column until you see it set to 'Album by Artist' Then select all the tracks in the problem album and Get Info Make sure the Artist, Album Artist and Album fields are set the same and that the box next to them is ticked. OK it. That should work, if it doesn't then retype those three fields with something else first, then OK, then retype them back to the correct info.
7 Sep 2008 at 12:11 #4 Twentymac Twentymac Associate OP Joined 2 Oct 2007 Posts 1,602 Location Birmingham ah yeah cracking ! didn't work first time so i just put "1" at the end of all the fields then it worked , then just changed the name back. cheers guys !!
11 Sep 2008 at 16:29 #5 danbroad danbroad Associate Joined 30 Sep 2007 Posts 75 another way is to select everything using the shift or apple keys, and clear ID tags. That resets the info, so you can proceed from scratch.
