Itunes Alternative
25 Nov 2005
Watford
I recently received an Ipod Video as a present. up to now i used musicmatch to organise my music. i have been using Itunes and it is starting to annoy me big style. i hate it.
any suggestions to a windows compatible alternative ?
My mate uses Anapod or something and says its a lot better than Itunes. DOnt know exactly how it works but it stops all the stupid copyright stuff Itunes uses.
Anapod
I'm using Anapod Explorer on my 60gb Video & it's great (I couldn't stand itunes).
There's different versions (I've got universal) and there's a trial edition. clicky
It even works on my windows 64bit :)
HTH
Anapod Explorer user here for over a year but I don't know why I-Tunes is bothering you.
My teenage daughters use it with no problems.
anapod is pretty good, i know many many people use itunes but I cant stand it. everyone says how simple it is but it just frustrates the hell out of me, and im a software developer :D
I much prefer just dragging and dropping into a folder as on a removable hard disk. so much easier.
The ipod i use is the missus, a nano. the thing itself is great. iv tried using i tunes again and iv found the only way i can use it properly is to install it on the laptop. and have a 2gig limit on my music folder ( same as the Nano ) and just keep the whole folder synced. it works great then.
The problems arose when I had it installed on my desktop with around 100gig of music. just found it was removing stuff and genreally being a pain in the arse.
is it to much to ask that if i want to put music onto my MP3 player that it doesnt
a: take over my PC with the bloated software
b: make alterations to the MP3s stored on my PC, just make a copy of them onto the player. thats all i want :)
3: force me to install other bloated software, I HATE QUICKTIME :(
lol, rant over with now, i feel so much better :D its a shame really, the nano is a lovely piece of kit. why they feel they have to be so controling as to what goes on it to an extent that it ruins the experiance is beyond me.
I bought two nano's at christmas for my girls.
a: I can't see any bloated software when it installed.
b: My girls open up Windows Explorer, drag and drop from Explorer into the right side of I-Tunes and they go straight on the IPOD without altering anything on the PC's hard drive. They have a 'sync' option turned off so nothing weird happens between PC and IPOD when they're connected.
c: Only I-Tunes was installed.
d: Its so easy two teenage girls can use it with absolutely no problems.
e: Anapod works in exactly the same way except it becomes part of your file manager.
I used to use an Iriver H340 which works with no fancy software. It just acts as an extra hard drive. To tag and maintain my music I used musicmatch (which I could use with the ipod but it does not support the video and photo side). I am more used to using this software. With Itunes, if you know no other music management software, then its not a problem, my dad uses Itunes with no problem at all. I am not saying that I can't use Itunes, i just don't like using it.
