26 Jul 2015 at 16:52 #1 N17 N17 Permabanned Joined 20 Jan 2012 Posts 680 After being so fed up with iTunes, are there any decent and free itunes alternatives out there, that I should look at?
27 Jul 2015 at 07:05 #2 eldergeek eldergeek Permabanned Joined 18 May 2014 Posts 1,072 Location The UK. Doubletwist?
27 Jul 2015 at 20:36 #4 Philtor Philtor Soldato Joined 20 Nov 2009 Posts 7,173 Using CopyTrans myself and find it very good.
27 Jul 2015 at 20:41 #5 tnx tnx Associate Joined 14 Dec 2012 Posts 1,060 Not free but very easy to use. Falling off a log would be harder. Code: http://www.imtoo.com/itransfer-platinum.html It does NEED iTunes to be installed for it to work though.
27 Jul 2015 at 20:42 #6 Akagi Akagi Caporegime Joined 29 Jul 2011 Posts 37,508 Location In acme's chair. Do you actually use an iPhone/iPod and need it to sync OP?
