iTunes auto sorting help
29 Jul 2004
Esher
Hi,
I haven't added any folders to my Music folder recently.
I used to download the album, put it into the Music/iTunes/iTunes Music/
folder then just drag the folder into iTunes and it would automatically sort the folder out correctly.
However, now that when I do it, it just adds it into the library instead of sorting out.
Also in the Music folder there are new folders called iTunes Media which has 2 folders inside called Automatically add to iTunes and Music.
If I add it to Automatically Add to iTunes it will sort the album and put it into the Music folder which is the subfolder of iTunes media.
Am I doing something wrong or is this how it works now?
