iTunes - Base and Center Speakers Not Working
12 Jun 2005
Hi there,
I have 5.1 Surround Sound setup and my Base and Center speakers don't seem to play the music.
The rear speakers are ok and when I do a sound test in the creative program and they respond (all speakers do)
Whats happening.
Thanks...
Hi there,
I am still having no luck.
I have a Sound Blaster Live! 24bit
I have tried playing music in Windows Media Player too, and still no joy, I don't get any output from the bass.
Thanks...
geez, 3 posts , enough with the bumping :p
have you tried updating your soundcard drivers or reinstalling itunes?
Hi there,
Sorry about the bumping its just I really what to sort this problem out as it is really annoying as you cant really listen to music without a bass.
I have tried both ideas without success
Thanks....
Hi there,
Have you had a look at your speaker setup in the Control Panel, Sounds and Audio Devices?
Thanks....
Hi,
Yes I have had a look and its set to the appropriate (5.1 Surround Sound).
I 99.9% doubt its a cable problem as the bass plays when i do a sound test in the Creative software.
Thanks...
Is it just in itunes you have this problem?
Is there an option in the itunes settings to tell it to use a 5.1 speaker system?
I've always had this prob with itunes aswell. Fine in everything else, but only left and right front speakers play tunes :( I just assumed it was because most tunes are stereo so don't use 5.1?
Hi there,
Thanks for your responses. I don't believe there is an option to set 5.1 speaker system in itunes.
I have the same problem in Windows Media Player too.
Well, I have onboard sound aswell and when I plug the speakers into that and use that to play music, the bass works...
Thanks...
