My iTunes seems to be having a very annoying semi-random error. If I'm changing playlists, it will often start glitching visually. I have a dual monitor setup, and it will suddenly appear on both monitors, but only half so, with bits missing and other random stuff. To work around I have to try and minimise it a few times and then it goes away. Sometimes I just have to close the app.
I tried getting a screenshot, but it wouldn't let me do it. Instead, I took a photo so you could see.
Any idea how I can fix this? I've just done a completely fresh install of XP, and it was doing it before the format.
If I can't fix this I'll have to find an alternative music+iPod manager, as this is driving me mad!
Any suggestions for fixes, or alternatives to iTunes?
Thanks!
Thanks!
