iTunes - Dual Libraries
Permabanned
30 Dec 2005
16,000ft
Hi,
I have 2 folders of music. On is Mahusive and contains every song under the sun, most of them twice, but has a lot of unnamed or crap stuff that I need to sort out.
I also have a second folder. This contains songs that are 100% organised and named.
What I want is to be able to flick between the two in iTunes, so that I can play music without wading through 1000s of results of carp, but then can switch to the other library to make a start at sorting the other stuff out when I want to.
Is there a clever way of doing this with playlists?
Cheers
Add the organised music to your itunes (file, add folder) and then create a new playlist called "Oragnised Music" and highlight, drag and drop all the tracks into that playlist.Then add your unorganised music and do the same for the unorganised music :)
