- 9 Dec 2015
Hey all
i'm not sure if this is the right place for this or not since this is a issue with the windows version of iTunes. I seem to be having a rather slow connection whenever I either download a new app, update exisitng apps or even trying to access my account through itunes.
App updates also seems to get stuck att he process file stage of a download. I should say that most of the time the store connection can be made and that sometimes a pop up suggesting a network timeout appears. I ahve attached some screenshots to show some of the issues i have been having.
and when i run a iTunes diagnostic these are the results:
Microsoft Windows 10.0 x64 Home Premium Edition (Build 14393)
MSI MS-7995
iTunes 12.5.1.21
FairPlay 2.11.7
Apple Application Support 5.0.1
iPod Updater Library 12.0
Apple Mobile Device 10.0.0.18
Apple Mobile Device Driver 1.67.0.0
Bonjour 3.1.0.1 (333.18)
Gracenote SDK 3.06.1.3084
Gracenote MusicID 3.06.1.3084
Gracenote Submit 3.06.1.3084
Gracenote DSP 3.06.1.3084
iCloud for Windows 6.0.1.41
iTunes Serial Number 000001F346F3872C
Current user is not an administrator.
The current local date and time is 2016-10-24 01:33:03.
iTunes is not running in safe mode.
WebKit accelerated compositing is enabled.
HDCP is supported.
Core Media is supported.
**** Runtime Libraries ****
c:\windows\system32\ucrtbase.dll: 10.0.14393.0
c:\windows\system32\msvcr120.dll: 12.0.21005.1
c:\windows\system32\msvcp120.dll: 12.0.21005.1
c:\windows\system32\msvcp100.dll: 10.0.40219.325
c:\windows\system32\msvcr100.dll: 10.0.40219.325
c:\windows\system32\msvcp110_win.dll: 10.0.14393.0
**** External Plug-ins Information ****
Plug-in Name: Last.fm AudioScrobbler
Plug-in Loaded: Yes
Plug-in Version: 4.0.5
Plug-in File Version: 6.0.5.4
Plug-in Path: C:\Program Files\iTunes\Plug-ins\itw_scrobbler.dll
Genius ID: 25158d28ac423fa3d680a87ef9c37b58
iPodService 12.5.1.21 (x64) is currently running.
iTunesHelper 12.5.1.21 is currently running.
Apple Mobile Device Service service 3.3.0.0 is currently running.
**** Network Connectivity Tests ****
Network Adapter Information
Adapter Name: {21B39748-B462-4D68-9F25-92E11E60897D}
Description: Realtek PCIe GBE Family Controller
IP Address: 192.168.1.6
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
DHCP Enabled: Yes
DHCP Server: 192.168.1.1
Lease Obtained: Sun Oct 23 15:57:17 2016
Lease Expires: Thu Jan 01 00:00:00 1970
DNS Servers: 192.168.1.1
Adapter Name: {49078D9A-47E6-4F46-8698-CD7541BD7C04}
Description: Intel(R) Dual Band Wireless-AC 8260
IP Address: 0.0.0.0
Subnet Mask: 0.0.0.0
Default Gateway: 0.0.0.0
DHCP Enabled: Yes
DHCP Server:
Lease Obtained: Thu Jan 01 00:00:00 1970
DNS Servers:
Adapter Name: {5B722CB4-7B0C-49BC-8955-F3D572CD14CD}
Description: Microsoft Wi-Fi Direct Virtual Adapter
IP Address: 0.0.0.0
DHCP Enabled: Yes
DHCP Server:
DNS Servers:
Active Connection: LAN Connection
Connected: Yes
Online: Yes
Using Modem: No
Using LAN: Yes
Using Proxy: No
Firewall Information
Windows Firewall is on.
iTunes is enabled in Windows Firewall.
Connection attempt to Apple web site was successful.
Basic connection to the store failed.
The network connection timed out.
Connection attempt to Gracenote server was successful.
Last successful iTunes Store access was 2016-10-24 01:32:19
MSI MS-7995
iTunes 12.5.1.21
FairPlay 2.11.7
HDCP is supported.
Plug-in Loaded: Yes
DHCP Enabled: Yes
IP Address: 0.0.0.0
DHCP Enabled: Yes
DHCP Server:
DNS Servers:
IP Address: 0.0.0.0
DHCP Enabled: Yes
DHCP Server:
DNS Servers:
Connected: Yes
Online: Yes
Using Modem: No
Using LAN: Yes
Using Proxy: No
