iTunes help please
20 Jun 2005
London..
Hi guys
Got some problems with iTunes on my MBP:
Duplicate songs. When I rip a CD and add it to the library, it seems to add it twice, and I can't seem to remove ANY songs from the library - delete is greyed out for every single song in the library. How can I fix this?
Also, How can I stop iTunes from automatically adding to the library every time a new MP3 file is created?
Thanks
I suggest you get in touch with AppleCare regarding this by calling them, or going to the Apple Store for an appointment if your a Mac user, however I would suggest that its likely some king corruption in your iTunes folder which can be solved by creating a new Library by holding down the option key when clicking the iTunes icon to open the app, then importing your songs by pointing iTunes at your old iTunes Music Folder.
To answer the 2nd question look in preferences, its in there, however is this whats causing the duplication on the first instance?
