Itunes help
Caporegime
18 Oct 2002
All over the world...
Need some help with Itunes, basically i re-installed windows vista on my laptop the other day and went to install itunes, which installed perfectly fine. I hooked up my ipod touch to it and it installed the drivers for it but for the life of me i cant figure out how to get all my music back onto it. Ive authorised my laptop but cant see anything in the menu that would allow me to put all my music back into itunes.
So does anyone have any ideas as to how to do this...i must be doing something wrong:p.
As above - or something like iPod liberator.
I've got a fully licensed (upto 5) machines copy of a windows app that lets you do it - if you can hang on til tomorrow, I can email you the app..
I'm off out now, but if you wanna email me (in trust) and I'll get back to you in the morning if you dont find a solution!
Good luck!
EDIT// I think the touch has a different filing system than the old school ipods - where you used to just be able to enable disk use and then view hidden folders, I think it was called ipod_control or something to that effect. But as I say, I don't think the touch will let you do that.. Might be worth a go?
Only downside is the fact that all your files are called random filenames in FXX folders, but when you import them all - they have all the data stored so they come into itunes fine...
