iTunes help
29 Jul 2004
Esher
Ahoy gents,
I have a really annoying problem with iTunes. Everytime I open it up I need to put my password in for my Apple ID account.
It's SO annoying, is there not an auto sign in function? Or am I blind
iTunes has been doing this to me too, I know theres a tweak on the iPhone iTunes Store app, but AFAIK there isn't any way to do this on a PC or Mac
Have you tried uninstalling ALL apple components on the computer and then re-installed again?
i sorted a problem this morning where itunes knew an ipod was connected but wouldnt sync as it thought I needed 64bit software, even though I had installed 64bit itunes :-S
Full uninstall and reinstall solved it for me
