iTunes help!
29 Apr 2015
Chaps
I've moved all my Music from "F:\My Music" to "Q:\Music". Now I don't use iTunes very often but I do have a decent old library in there, but obviously nothing plays at the moment.
I don't want to have to locate 3000 songs individually so is there a method of changing the file paths en masse?
Can't you just Add Folder to Library
Ps would delete everything from the iTunes library first before adding the new location
If you change the location and then right click a few of the files and select locate and point to new location Itunes should come up and say do you want to search in this location for the rest of missing files or similar, have had this when moving iTunes to new pcs and seems to find most and relocate them
Chris
