1 Jun 2006 at 19:08 #1 SamG SamG Associate Joined 28 Nov 2004 Posts 950 Itunes imports double what it should so instead of copying 12 tracks it will double that and import 24. So I end up with a lot of copies. Why is it doing this and anyway around it?
2 Jun 2006 at 13:09 #2 The B.A. The B.A. Associate Joined 16 Mar 2006 Posts 113 Location Down the road sam garland said: Itunes imports double what it should so instead of copying 12 tracks it will double that and import 24. So I end up with a lot of copies. Why is it doing this and anyway around it? Click to expand... Where are you importing the tracks from and how?
2 Jun 2006 at 15:25 #3 SamG SamG Associate OP Joined 28 Nov 2004 Posts 950 Sorry I should have said. I'm importing the tracks from a folder. Using the add folder to library.
