Why didn't I try restarting my pc...
SOLVED lol
Grr,
Re-installed windows and i wanted to change my partitions. Everything is installed apart from Itunes.
I downloaded the installer and ran it and i get this:
Any ideas what to do for a fix?
Should add it was perfectly fine before the reinstall
Thanks
EDIT: Managed to download version 8.11 but i try to update i get
SOLVED lol
Grr,
Thanks
Rather stupid.. Even though i selected 64bit version it installs in the (*86 program files) can't remember if it did that last time.Errors occured while installing the updates. If the problem persits choose tools > downoad only and try installing manually
