Hi all,
I'm using (I think) the latest version of iTunes on my Windows 7 desktop, with my music stored in D:\Albums
I want to move this, so that it will be on a different drive, but with the same path, i.e. F:\Albums. It'll be a network drive if that makes any difference.
Can I just do a find and replace or whatever, in the iTunes library XML files? I don't really want to have to go through the faff of re-adding all my music to iTunes like I seem to whenever I reformat.
Thanks!
Thanks!
- Basically I reckon if you just move the lot and tell iTunes via the alt switch where the new one is you'll be fine
