itunes on vista 64bit not working :(
18 Feb 2008
London
i upgraded to vista 64 bit (as now have 4gb memory) but i installed itunes 64bit and it runs but tells me it is not a 64bit version and will not work when i go to uninstall it encounters and error and cannot complete removal, i've tried to reboot between and no luck, is this a common error?
I had some problems running iTunes 64.
If you open up the setup exe file in a zip tool you will see several .msi files, one of these has a file name containing Apple and mobile, run this. (apologies about tbeing vague in the file name but it's from memory)
This sorted my problem out.
Use IE7 goto apple and make sure you get the 64bit version of apples software, it has/had some issues picking up the os.
I'm running itunes on vista x64 ultimate without issue although not as smoothly as on xp.
