Itunes Purchase from outside UK
15 Feb 2008
Hi,
I have never used itunes before but have found a TV series on the Australian itunes and was wondering if it is possible to purchase this from the UK? for playback on my PC.
My only payment method is via a uk registered visa card.
thanks.
Yes, but you won't be able to use your UK account to buy it.
You'd need to create an account on the Australian itunes and fund it with gift cards (usually available on ebay).
Yes like LFetcher says, you have to create an account on the Australian iTunes.
I had to do this for some Japanese Apps which is pretty annoying since it doesn't allow you to update X or Y Apps unless you logged into the account you downloaded them with. :/
