iTunes remote to iPhone on a non wifi setup.
So long as the HTPC is on a wireless radio network it doesn't matter if it connects through the wifi or using a network cable. It just needs to be on the same network.
My main PC is hardwired to my network (ADSL wireless router) and I can access it fine with my iPhone over the wifi :)
Mine works perfectly via a wired network. My Mac Pro is connected via a cable to my router and I can control it with Remote.
/edit - Curse my slowness but I did install it and set it up to test before posting :)
