Hi all,
I am after a replacement for iTunes, for some reason some of the MP3's the missus has will play fine in other players but not iTunes.
The software needs to be able to write to an iPod, maybe read from it as well in order to import songs that are on there, stream radio stations and play as many types of media as possible. One important thing is that you should be able to burn music CD's from it.
Any suggestions?
Buying music through it isn't an issue, lots of websites that allow you to do that!
thanks
Any suggestions?
thanks
