iTunes sync speed - iPhone 3G
17 Mar 2004
How long does it take you guys & gals to sync apps on your iPhone 3G. I have a 1.5GB app (TomTom) and it takes around 30-40 mins to sync USB 2.0 in any Window O/S environment. Is this normal?
Phone is blank, after a fresh installation of the new firmware 3.1.2.
Thx
Something isn't right there. My old 3G sometimes took a while to do the 'back up' stage when it was plugged in, a few seconds for just syncing apps thought.
Cant offer you a solution however :/
C.
Im pretty sure thats normal, I remember it taking about 10 minutes to install CoPilot on mine which i think is around 200 odd megs
