iTunes syncing
1 Mar 2007
Portsmouth
Just curious to see how you all have your iTunes setup to sync with your iPhone/iPod? I keep having the trouble with that fact that my iPhone is 16GB and I end up syncing my whole library and just delete/add files to my library each time.
It would have been far easier for iTunes to have had an option to sync selected albums like they do with artists for me anyway.
It does have that option, you need to tell it to Sync Music, but in the next box not all, then specify the albums, further to this you should make sure your running the latest update, this might be why you haven't seen the option.
Thanks, but the only option I get is either 'entire music library' or 'selected playlists, artists and genres' there isnt an option just for albums.
Yeah iam on 9.2
