Itunes : Warning
18 Oct 2002
Cambridge, UK
Hi,
Running Win7 Ultimate x64, anybody seen this error in Itunes:-
HEADRAT
Not seen that
The 32bit version will refuse to install on Win7 64bit so not sure whats going on there.
I suggest uninstalling, re-downloading and installing as administrator (right click)
Sounds like something you have installed after you installed iTunes has modified the registry in a way it doesn't like. If you reinstall iTunes it will make the necessary registry changes - whether or not that breaks the other program I don't know.
