ITX Advice needed
20 Jan 2010
Hi. I am looking to build my first ever ITX PC. I want to use it solely as my main PC.
I won't be gaming on it. It needs to be very nippy but at the same time not use vast amounts of electricity.
I quite like this motherboard:
Intel® Desktop Board DG45FC
Now, what CPU would you recommend to go with it, and ram. As i said, i don't game but need a nippy PC.
I also want as small an ITX case as possible and what about a suitable PSU? Is it possible to use a Pico PSU and if so, which one?
So, is that mobo a good one (It has onboard graphics which is great for my needs)
What CPU would you recommend
What ram?
What PSU
What case? Small as possible.
I already have a good 2.5 HD.
What exactly do you plan to use this for? Web/Office/Encoding?
I would suggest either the E5200 or E8400 budget/performance requirements depending. Then any 2 - 4 Gb DDR2 SDRAM kit as you do not seem to be after performance.
Sorry I do not know how good the board is, but you are not really going to be going crazy overclocking if you are trying to make a low power rig here are you?
Good luck!
You could go pico PSU but you might as well go for something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-OP&groupid=701&catid=7&subcat=1582
Its budget, has option for 1x5.25", 1x3.5" and 1x 2.5" drives. It looks nice and I currently use it for my home server. The 80mm case fan is noisy so I would recommend replacing it and you will likely need a low profile intel cooler so be careful height wise on that.
Other than that you are away.
Been looking at a couple of ITX boards and these 2 have been brought to my attention:
Intel DG45FC Socket
Zotac GF 9300-I-E
Which would the better of the 2? I want onboard GPU and be able to use 4gig of ram and a dual core CPU. thanks
