A620/APU build as above should be doable if you're only buying new parts. Used however opens up more options for something like an 7500F/7600 + A620I or Or 12400F + H610I with a 2nd hand GPU depending on what you need.
Yep, totally do-able, buy second hand/something that has a fault.
I bought a B450i/3500X/16GB ram/RX 580 8GB MITX 2nd rig off a mate at what he paid last year with a faulty gpu - £280, and just upgraded bits as I went - it lives in a SG-13 btw
So you shouldn't have a problem doing this with any spec build, just get a reasonable motherboard and a 'good enough for now' cpu/gpu and upgrade it over time once you're up and running?
Having a quick look, I could quickly put together this list brand new. PC Partpicker estimated PSU usage at 159W with these parts so far.
5600G - £125
B550 Micro ATX board - £95
16GB DDR4 - £36
SN770 500GB - £53
550W PSU - £57
£366 so far with £134 spare, but not sure if you need an OS. But you could easily get any parts on MM from other users. Just a thought.
I bought a second hand 1600/b350/16gb/750ti not sure case or PSU but were branded for £100 off facebook. Stuck a 3600 in (Annoyingly 5xxx bios came out few days after), 3050 and a 1tb NVMe in Cost me £450 all in May 2022.
