I already have a HTC Vive and a gaming PC running on a GTX 1060 6GB.
I often get asked to bring my HTC vive to parties, and also plan on taking it to Spain in september, but my PC is pretty heavy.
Instead I want to build a cheap ITX PC, using the GTX 1060 from my current PC.
I heard others on reddit recommend getting a 2nd / 3rd gen i5 ITX motherboard, as they are dirt cheap and good enough for VR.
My main question, is what is the requirement for a PCI slot on an ITX MB? I'm looking at an Intel DQ67EP which lists "PCIe x16 Gen 2.x". Would this be enough for a GTX 1060 to run? If not, what should I be looking for?
Thanks.
Thanks.
