ITX Build - what Graphic Card...need help
7 Aug 2014
Kent
So i'm building a ITX build Specs:
MB: Asus Impact VII
CPU: I7 4790k
RAM: 16GB 2666mhz C11
PSU: Silverstone SFX Strider "Gold" 600w
my question is: is the 980 the best card for a itx build now? size doesn't matter and I cant get a 295x2 due to the PSU
everything will be Water cooled / overclocked and I only have the graphic card to get
so what graphic card would you recommend ? and why ?
That's what I thought the 980, the case I have gone for is the air 240, with 480mm rad space and might be added another 120mm so total 560 rad space, I know its a m-atx case but with a itx I could fit another 240mm rad in and I didn't want to go sli anyway as this is my last ddr3 build! Also the case is still small enough to move around for lans as I was going to get a 380t which is the same size.
So yeah price isn't really an issue for me just size due to where it will be homed!
