itx case coolermaster 130
2 Jan 2010
Good morning ,
i wrote a topic yesterday about downsizing my current atx z11 build, constantly got the other half nagging to put it away etc ( its currently sitting behind are tv in the living room) out of sight out of mind...
but to be fair to her its pretty big, and all the wires are doing her nut in...
had a good suggestion on a case but after sorting finances out i decided to buy a cheap h61 mitx board, i have a i5 4670k i know i lose the ability to OC but when space is tight i want to keep temps down....
so im looking for a case now, and after a few searches last night the coolermaster 130 looks pretty good for the money, budget is max £60 so i have 20 pound to spend on a low profile cooler IF i need one , thats another question i need to ask you guys, about if the stock fits in....
anyways im open to suggestions, sorry its got to house a vapor r9 270x also, for playing the odd game here and there, and will also be used for xbmc or should i say KODI.
Thanks
The 4670k will not work in H61 Motherboards, those are for s1155 chips.
The 4670k is s1150, compatible chipsets are H81, B85, H87, H97, Z87 and Z97.
As for the case, sure the stock HSF will work no problem.
