ITX case that can take a 290X Tri-X?
10 Dec 2004
Oxfordshire
I know its most likely a big ask as this card is HUGE! at 305mm but are there any ITX cases that can fit / keep this card cool?
Ta
Ben
A Fractal Design Node 304 can fit it, though it will be very tight unless you use a short or SFX PSU. It has a side vent to get air to the GPU so temps should be ok. Unless the Tri-X is a 2.5 slot wide card? I know that I couldn't fit a Ice-Q 7950 in because the damn cooler was too fat!
