ITX case with 180° orientation?
28 Jan 2007
London
Hi guys
Anyone know of an ITX case that supports this type of layout?
The BitFenix Phenom M is close but it's MATX so much larger than need be.
Or imagine the Corsair Air 240 turned upside down (again MATX so bigger than need be).
Well this was a duh moment :o
My reason for wanting this upside down layout was based on the misunderstanding that GPU fans push heat AWAY from heatsink. In my example image this would mean they push air UP, resulting in one straight vertical channel of air - cool air pulled in from bottom provided to the GPU which would help exhaust it out the top.
They actually draw cool air IN so the GPU would be conflicting with this and the standard motherboard orientation is most optimal.
I quit.
