Hi guys i'm looking for an itx case i have just brought an old itx mobo from mm (only £10
) I want the case as small as possible i want it to be portable. I might upgrade the itx motherboard if i enjoy fiddling with it to an intel atom as they seem really cheap for what they are.
The case needs room for a small PSU unless i can get my hands on a psu with a brick. It doesn't have to have room for a hard disk as i might run it off a compact flash card. Doesn't necessarily need space for a dvd drive but i would be using a slim dvd.
I was thinking i could maybe mod the case so i can have a touch screen on it. 7" screens go for £20 on the bay
. the case needs to be cheap ish nothing over £80 really
My only other option is to make one myself and i'm not so good with metal lol
) I want the case as small as possible i want it to be portable. I might upgrade the itx motherboard if i enjoy fiddling with it to an intel atom as they seem really cheap for what they are.The case needs room for a small PSU unless i can get my hands on a psu with a brick. It doesn't have to have room for a hard disk as i might run it off a compact flash card. Doesn't necessarily need space for a dvd drive but i would be using a slim dvd.
