ITX cooler
10 Jan 2012
Will a Phanteks PH-TC14PE be able to fit on this motherboard with a graphics card installed or is the cpu socket too close to the pci-e slot?
or would I need a motherboard with this spacing
Is there any other decent itx motherboards except the 2 above?
Heatsink Dimensions without fan 134 x 140 x 160mm (LxWxH)
Heatsink Dimensions with Dual Fans 159 x 140 x 171mm (LxWxH)
Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
