Hi guys,
Still a slight work in progress here and I haven't really got any pics of the process up till now (because they're not really that interesting anyway) but it should still be a pretty decent little system when it's fully finished. It's not the smallest of ITX cases, but it lets me get all the hardware I wanted in there with pretty much no compromises.
Full specs are these new components:
Fractal Design Nano S Case
EVGA SuperNOVA 650w G3 PSU
i7 7700K
Asus Strix Z270i Motherboard
16GB 3200MHz Corsair Vengeance LPX
Asus GeForce GTX 1080 Ti Founders Edition
2TB Western Digital Blue (Storage)
Then recycled from another system:
Samsung SM951 NVMe 128GB SSD (for OS)
500GB Samsung EVO SSD (for games)
750GB Crucial MX300 SSD (for games)
Up until yesterday, it had a Corsair H100i GTX doing the job of cooling the CPU and it looked like this:
Since I needed to buy another cooler to replace the one in the system I'd just nabbed the H100i GTX from, I figured I may as well go all out. I grabbed the EK Slim 240 kit since space is at a bit of a premium and for now, here's how it's looking:
Making better use of that small amount of free space in the case
I need to get the pump/res mounted properly as it's just sat on the graphics card for now so that's today's job. At the moment as you can see, only the CPU is under water. I will be buying a second radiator and block for the GPU hopefully later in the month and likely a couple of angled fittings to get the tubes to run a little bit neater.
I did think about hardline tubing but I know I'd make a mess of it and although it doesn't look as good, I prefer the ease of rubber tubing should I ever need to move things about from time to time.
So, to do list at the moment whenever I get round to it:
* Mount the pump properly
* Add a second radiator and GPU block
* Replace those damn red and blue SATA cables with black ones
Haven't put much effort into overclocking the CPU yet but I have delidded it:
Probably a bit premature especially if I got a poor overclocker but since even if I did I wouldn't be the type to return it anyway, it doesn't really matter. Temperature reduction under the H100i was pretty good, from 72 degrees C at stock under Prime95 (non AVX) load to around 60 degrees C under Prime95 load. From looking at the paste pattern left on my CPU and the H100i block when I removed it, I'm not entirely sure it was fitting quite right anyway so it'll be interesting to see what I'm getting with the EK kit now
i7 7700K
