ITX htpc
3 Jan 2003
guys will the orginal Acer revo 3600 (atom 230 single core) handle 1080p video?
thinking about getting 1 and putting Win7 on it and using media center ;-)
the acer revo 3600 is around £150 or I could be my own
Depends on the source of the file. Flash is not offloaded to the GPU yet; so HD files from Youtube (for example) struggle as the processing is all on the CPU.
I got asrocks ion 330 and I think it is pretty quiet. It isn't dead silent but there is one fan running in this machine. If you are planning to watch HD movies on it... I suggest you should go Linux route and use xbmc.
