ITX motherboard back panel
21 Nov 2008
Ripon
Its a random question but does anyone know the actual dimensions of the itx panels for a project im making and I dont have one here to measure
Im not sure who this belongs to but it may be useful to you.
ITX motherboard is 170mm x 170mm but guessing you probably already knew that.
Obviously with ITX you traditionally only need the first two PCI slots, unless you have a 2.5 - 3 slot GPU.
Edit:
Also found this document, if you scroll down to page 9 it has the mounting hole diameters and distances.
http://www.formfactors.org/developer\specs\mini_itx_spec_V1_1.pdf
