ITX with dual Intel lan
4 Jan 2004
Nottingham
Hey Guys
I'm on the look out for an ITX board with dual Intel network adapters on it that's sandybridge/ivybridge/haswell based. I've seen a few Gigabyte boards with dual Realtek nic's but Ideally I'd like dual Intel nic's. I'm also planning on adding a raid card so can't go for a Intel PCI-e card.
Has anyone seen anything on their travels? Seen some awesome server/workstation boards but from what I've seen they are either quite pricey, hard to find or don't support S3 sleep (another feature I'd like)
Cheers
Why so discouraged from the Realtek boards? The Intel based boards only gets marginally better throughputs so unless it was for something doing constant read/write operations over the network at full tilt you will be fine with a Realtek nics
I have the Asrock C2750D4I that Frozennova mentioned. Support for 32GB RAM was the main reason I chose it, but the dual NICs have come in handy for running the lab simulations I need for my studies. It is, however, an expensive option if your main requirement is dual NICs.
Edit: there are some other, cheaper options. The Jetway JNF9J-Q87, for example, has dual Intel NICs, supports 16GB RAM and is significantly cheaper than the Asrock.
