Ive bought everything for my build but i lack a case...
27 Sep 2011
Good Evening all
After Taking a load of advice on the forums and reading quite a few threads ive pretty much got my parts together to do my very first build and id like to begin a build log. only issue i have is i still lack a decent case. My initial idea was to use my existing Akasa eclipse but after seeing some of the fantastic builds i think id like a much more modern look with a window and lights etc.
Here is my parts list
Intel I5-2500K CPU
Asus p8z68 Pro/gen 3
8 Gb of Ripjaw dual memory ( another 8gb on order)
850W OCZ Z series PSU
ASUS GTX 580 Matrix Platinum
1tb Seagate Barracuda HDD
60GB OCZ Agility 3 SSD
2X Samsung Blu-ray/dvd roms
Kone + Mouse
ASUS Xonar Sound Card
Antec 620 CPU cooler.
My Initial thought was a white Cosair 600T as they seem to very popular and reasonably easy to build into since its my first attempt. I was wondering though if the Asus GTX 580's size is a limiting factor and whether i need to go for a full size case.
My other choice was the V2 Raven RV01 which i really like the look of but i noticd that a lot of people mention the RV02 case. should i consider the RV02 over the RV01.
Other than that any other choices and opnions will be gratefully received. apart from the cpu cooler i want to stay aircooled and if possible something that looks smoother than cases like the Haf x with huge amounts of drive bays.
Thanks for any ideas or suggestions
Ian
edit: appologies if this is in the wrong section. i didnt know if cases or general enquiries would be the best place for the thread
I have a Fractal Arc and love it. Added a window to show off the white internals and a stealth drive mod looks very understated but quality. Best case i have bought
For me, case choice is more about finding a case that looks good as much as anything else, I would hunt through the case section and find one you like the look of, then decide if there is any features you need that it doesn't have.
Cheers for all the replies
i think your right i have to go with what i want visually as well as what i need hard ware wise so i just ordered the White 600T as its always been the one that ive fancied.
Now all thats ledt it to build the machine and get bf3 and mw3 amongst others
Thanks again
Ian
