I've built this.Advice needed
My basket at Overclockers UK:
Total: £1,656.83
(includes shipping: £0.00)
The above spec is what you've picked and comes out to £1,779.92 (shipping included) in the Build Configurator.
You could go with the following (with GTX 1080):
Total: £1,686.87
With the build fee (it can vary) it should come out to the same or under perhaps.
You can post your selection of parts in the Customer Service forum, if you can't find a pre-built you're entirely happy with. OcUK will then quote you and advise of any incompatibility or alternatives for parts not in stock, etc.
Before pulling the trigger, do you have a nice monitor already to make good use of a 1070 or 1080? And do you have Windows?
Thanks for the feedback. Ended up ordering my first choice at a good price. I do have a Samsung s27d850t monitor which I think it would be fine.
thanks again
