I've lost the keys to my Lian-Li V2000 case plz help!
well, with the side panel off, I can see the other side of the latch of the lock, so if I can either cut it, or bend it up then I'm home and dry, but can't lock the case anymore...Not that I've ever needed too :rolleyes: Only locked it when it was stored in the garage so the door wouldn't fly open when I was moving/carrying it :p
Have a fiddle with a paper clip. If fallout taught me nothing else it was that lock picking is easy.
20% chance to force.
Seriously though if all the keys are the same and you have no time constraints beg someone on here with that case to cut you a key and post it.
Just forced it, thank you 20% lol. Somehow, I've not broken ANYTHING after using a blunt chisel and a HAMMER to bend the latch up and through the slit in the case! I've now removed the bolt holding the latch onto the tumbler axle so I can close the door freely, but if I find the key, I can reattach the latch and use the lock again.
I think I drank some Winsauce!
