Here are the photos, the 2nd one shows the case after i'd removed the inner panel and resprayed it......new Phanteks LED fans, it now has loads of room inside, the side window shows just how strong the case is..
i've downgraded the InWin to 8.5 out of 10, it's easily the best looking case i've seen, but is a bit of a sod to work on plus they've made a few errors -
cons:-
1.........the replacement front fans only just fitted, thanks to those stupid latches
2.........no front filter, this needs to be made by you....unless you buy something from here
3.........roof vent filter is totally lame........just remove it
4.........silly inner panel which is really hard to remove, EVEN FOR ME !
5.........NOT SURE ABOUT THE QUALITY OF ITS PAINT JOB
good points:-
1......looks beautiful, it's styling is almost perfect, whoever designed this has got a lot of flair
2......big inside
3......strong as a Bull
4......great ventilation
5......side panels come off really easily
6......loads of room behind mobo
7......massive floor vents if needed
8......very nice upper cage
9......very clever front door panel
10.....case is very wide
