I've Uninstalled Macrium Reflect
25 Jun 2006
Somewhere East of Eden
Could someone please advise me?
I've uninstalled Macrium Reflect as per their instructions:
https://kb.macrium.com/KnowledgebaseArticle50112.aspx
Unfortunately there are still a number of traces of Macrium on my system. The ones giving me most concern are located at: C/Boot/Macrium which contains two files
1st. "Drivers" contains empty folders and one search paths.txt file.
2nd. "WA1OKfiles" contains many files and folders the size 250MB
If they weren't on the C Drive, I'd just delete them.
Would it be safe to delete these two files?
Thanks
Thanks, from the link I gave I did tick the box "remove all generated.........files" but files are still on the system. Is there another option for the boot ment?
Thanks
If the app has been uninstalled, then just Shift+Del these folders - the fact they reside on the %systemdrive% doesn't make them special - other than being 'protected' by a UAC prompt that is :)
The windows boot menu option will still appear, yes you could remove it using bcdedit but it's easier to just re-install macrium.
That's a shoddy uninstall if it still leaves behind such a prompt - though a quick jaunt into msconfig ought to resolve it pretty sharpish, I'd have thought.
Thanks everyone I used Scort's suggestion and removed them. I checked MSCONFIG and Macrium does NOT appear there.
Thanks again
