12 Dec 2012 at 15:44 #1 smilertoo smilertoo Soldato Joined 4 Aug 2005 Posts 3,364 Hello, Do you have the option to disable the IGP on the ivybridge cpus to reduce power usage/heat and possibly increase cpu overclocking?
12 Dec 2012 at 16:05 #2 ubersonic ubersonic Soldato Joined 26 May 2009 Posts 22,226 Yes, should be in the BIOS, something like "Onboard GPU: Auto/Enabled/Disabled".
