HI there
We've setup some new SKU's specifically for Ivybridge, these parts work with all platforms as Ivybridge has no specific memory requirements, as long as its Dual Channel with an operating voltage of 1.25-1.65v, but to celebrate Ivybridge check out these new lines due end of this week:-
G.Skill TridentX 32GB (4x8GB) DDR3 PC3-19200C10 2400MHz Quad Channel Kit (F3-2400C10Q-32GTX) @ £359.99 inc VAT
Working closely with its motherboard partners, G.SKILL has completed the compatibility validation tests between the current DDR3 memory kits and the latest Intel 7 series chipset-based systems. G.Skill guarantees all of its performance DDR3 memory kits are able to deliver the best performance and reliability with most popular Z77 motherboards in the market
In addition, all G.SKILL high speed DDR3 memory kits (including and above 1866MHz) have included the latest Intel XMP 1.3 profile support to Z77 motherboards. It allows PC enthusiasts to easily enjoy the high memory speed on the latest Z77 platform without setting the BIOS manually .
All G.Skill memory products come with a lifetime warranty and the G.Skill technical team is always ready to provide consumers with complete technical support via online forums, telephone and email.
Features:-
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Capacity: 32GB (8GBx4)
- Multi-Channel Kit: Quad Channel kit
- Tested Speed: DDR3-2400 MHz (PC3-19200)
- Tested Latency: 10-12-12-31 2N
- Tested Voltage: 1.65V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM
- Height: 54 mm / 2.13 inch
- Warranty: Lifetime
- Fan lncluded: No
- Features: Intel XMP (Extreme Memory Profile) Ready & Removable Top Fin
Only £359.99 inc VAT.
ORDER NOW
G.Skill TridentX 16GB (4x4GB) DDR3 PC3-19200C10 2400MHz Quad Channel Kit (F3-2400C10Q-16GTX) @ £203.99 inc VAT
Features:-
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Capacity: 16GB (4GBx4)
- Fan lncluded: No
Only £203.99 inc VAT.
ORDER NOW
Corsair Vengeance Black 16GB (2x8GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (CMZ16GX3M2A1866C9) @ £179.99 inc VAT
Great Looking, Great Overclocking Memory at a Great Price
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. As a bonus, the attractive low price of Vengeance memory will also leave lots of room in your system build budget.
Optimized for Compatibility with the Latest CPUs and Motherboards
Vengeance memory is designed specifically for the latest CPUs. Vengeance modules run at 1.5V for maximum compatibility with all Intel® Core™ i3, i5 and i7 processors, as well as the 2nd generation Intel processor family. Vengeance DDR3 memory is available in single modules, and two or three module kits, making it easy for you to match the DIMM population requirements of your motherboard.
Features:-
- 16GB (2x8GB) DDR3 for AMD and Intel Dual Channel processors.
- 1866MHz
- 9-10-9-27 latency
- Vengeance heat spreader for styling and performance
- Intel XMP 1.3 (Extreme Memory Profile) Support
- Limited Lifetime Warranty
Only £179.99 inc VAT.
ORDER NOW
G.Skill TridentX 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (F3-2400C10D-16GTX) @ £199.99 inc VAT
Features:-
- Model Number: F3-2400C10D-16GTX
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Capacity: 16GB (8GBx2)
- Multi-Channel Kit: Dual Channel kit
- Fan lncluded: No
Only £199.99 inc VAT.
ORDER NOW
G.Skill TridentX 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (F3-2400C10D-8GTX) @ £99.95 inc VAT
Features:-
- Model Number: F3-2400C10D-8GTX
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Capacity: 8GB (4GBx2)
- Fan lncluded: No
Only £99.95 inc VAT.
ORDER NOW
G.Skill RipJawsX 16GB (2x8GB) DDR3 PC3-17066C9 2133MHz Dual Channel Kit (F3-2133C9D-16GXH) @ £179.99 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Features:-
- Model Name: F3-2133C9D-16GXH
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- M/B Chipset: INTEL Z77
- CAS Latency: 9-11-11-28-2N
- Speed: DDR3-2133 (PC3-17066)
- Test Voltage: 1.6V
ORDER NOW
G.Skill Ares 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (F3-1866C10D-16GAB) @ £143.99 inc VAT
G.Skill has announced their latest edition to their award winning RAM with the addition of the Ares Range. This is ideal for those building or upgrading a system where Cooling low profile memory is essential to work with the latest coolers. The Heatspreaders are at a minimal 1.26 Inches (32mm). The latest ARES Ram has been designed to offer maximum performance on the latest Intel and AMD Platforms
Building on the strong success of the of Ripjaws X and Ripjaws Z performance memory kits, every single G.Skill Ares memory kit is hand-tested in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology! The following list shows the detail specifications of G.Skill Ares family.
Specifications:-
- Model Number: F3-1866C10D-16GAB
- XMP Profile: 1.3
- Main Board: AMD & Intel
- System: Desktop
- System Type: DDR3
- CAS Latency: 10-11-10-30
- Capacity: 16GB (8GB x2)
- Speed: DDR3-1866 MHz (PC3-14900)
- Test Voltage: 1.5v
Only £143.99 inc VAT.
ORDER NOW
G.Skill RipJawsX 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (F3-14900CL10D-16GBXL) @ £139.99 inc VAT
Features:-
- Model Name: F3-14900CL10D-16GBXL
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- CAS Latency: 10-11-10-30-2N
- Speed: DDR3-1866 (PC3-14900)
- Test Voltage: 1.5V
- Package Height: 40mm / 1.58 inch
- Black PCB
Only £139.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CMZ16GX3M2A1600C10) @ £99.95 inc VAT
The new 16GB Vengeance DDR3 kits operates at 1.5V for compatibility with the new 2nd generation Intel® Core™ processor family and is guaranteed to operate at 1600MHz. Providing 8GB of rigorously-screened DRAM on a single module allows gamers and performance enthusiasts to build systems with 32GB of high-performance memory.
"Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget," said Giovanni Sena, Director of Memory Products at Corsair. "Our kits based on 8GB modules give builders, system integrators, and gaming enthusiasts the power to break the 16GB barrier."
Features
- 8GB Modules
- Each twin module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
ORDER NOW
We also highly recommend the following products for Ivybridge too:-
Corsair Dominator GT 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit with DHX Pro Connector (CMT8GX3M2B2133C9) **SPECIAL** @ £149.99 inc VAT
CORSAIR DOMINATOR®GT 8GB (2x 4GB) ultra-high performance kit for Intel Core i7, dual channel processors. 2133MHz, 9-11-10-27, 1.5V, with Intel XMP. Includes the COSSAIR Airflow Fan and connector for the optional Airflow Pro Activity and Temperature Monitor (sold separately).
The DOMINATOR®GT is the ultimate performance memory solution. Limited to only extremely high memory speeds, the CORSAIR DOMINATOR®GT only uses highly screened IC’s to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology.
- Two matched 4GB modules for use in high performance Intel Core i7, i5, and i3 dual channel processors
- Outrageously fast 2133MHz performance using 4GB of memory
- Ultra-low 9-11-10-27 latency
- Intel XMP (Extreme Memory Profile) Support
- Airflow Fan
- Density: 8GB (2x4GB Module)
- Speed: 2133MHz
- Timing: 9-11-10-27
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50V
Only £149.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9B) @ £52.79 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Lifetime Warranty
Only £52.79 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLE2CP4G3D1869DE1TX0CEU) @ £47.99 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Temperature Probes
- Crucial MOD software compatible
- Elite heat spreader for performance
- Tested together at 1866MHz, Vdimm = 1.60V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1866MHz, 1.60V
- 100% tested at 1866MHz in Intel based motherboards
- Lifetime Warranty
- Bulldozer compatible
Only £47.99 inc VAT.
ORDER NOW
G.Skill Ares 8GB (2x4GB) DDR3 PC3-17000C11 2133 MHz Dual Channel Kit - Orange @ £71.99 inc VAT
Specifications:-
- Model Name: F3-2133C11D-8GAO
- XMP Profile: 1.3
- System: Desktop
- System Type: DDR3
- CAS Latency: 11 11-11-11-30
- Capacity: 8Gb (4GB x2)
- Speed: DDR3-2133Mhz (PC3-17000)
- Test Voltage: 1.6v
Only £71.99 inc VAT.
ORDER NOW
Corsair Vengeance Gold 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9G) @ £45.59 inc VAT
Serious about PC memory? So are we.
Like the legendary Dominator, enthusiast-grade Vengeance DRAM is designed for stability, stringently factory-tested, and backed by our limited lifetime warranty. And, we know that great looks are as important as great performance. This is why Vengeance modules come in a variety of colours to match your components and let you build your system just the way you want it.
Overclocking your components can be a fun and rewarding way of pushing your gaming PC to its performance limits. Vengeance can help make this happen. Before each module is assembled, the DRAM chips are individually screened not only to ensure reliable meeting performance specifications, but to allow generous headroom for stable overclocking.
Optimized for Compatibility with the Latest CPUs and Motherboards, Vengeance memory is designed specifically for the latest CPUs. Vengeance modules are available in 1.5V and 1.35V configurations for maximum compatibility with all Intel® Core™ i3, i5 and i7 processors, as well as the 2nd generation Intel Core processor family. With dual channel, triple channel, and quad channel kits, there's a Vengeance configuration that's perfect for your motherboard.
XMP Memory Profile for simple, safe overclocking, Vengeance memory supports the Intel XMP (Extreme Memory Profile) standard, and each module is individually factory-programmed with an XMP profile indicating supported timing, frequency and voltages. Just enable XMP on your compatible motherboard and you'll automatically get optimized memory overclocking without having to deal with multiple BIOS settings. Of course, if you're an experienced overclocker - or an aspiring one - you can adjust the settings to push for even higher performance.
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.35V for motherboards using AMD, Intel First and second Generation Core processors dual channel platforms. Vengeance memory modules provide users with outstanding memory performance and stability with loads of overclocking headroom. Vengeance Each module is built using carefully selected DRAM to allow for the best performance and a limited lifetime warranty.
- 8GB (2x4GB) DDR3 for AMD, Intel Dual processors
- 1600MHz
- 9-9-9-24 latency
- Voltage: 1.35V
- Vengeance Military Green heat spreader for styling and performance
- Compatible with Sandybridge and Ivybridge
Only £45.59 inc VAT.
ORDER NOW
Kingston HyperX RED Limited Edition 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3B1RK2/8GX) @ £44.99 inc VAT
Kingston’s HyperX® Red Limited Edition is specially designed to enhance high-performance systems. It features a sleek and aggressive look to complement any compatible motherboard and desktop computer. HyperX Red Limited Edition is available in 4GB single modules or 8GB kits. It comes in speeds of 1333MHz and 1600MHz and voltages of 1.5V and 1.65V to meet the demands of gamers, enthusiasts, system builders and consumers looking for high-performance upgrades.
HyperX Red memory modules have been maximised for optimal heat dissipation. In addition, the 1600 MHz 8GB kits are fully XMP-ready to enable easy overclocking for optimum performance. All HyperX memory products come with a lifetime warranty, free technical support and legendary Kingston® reliability
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Warranty: Lifetime
Only £44.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £44.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Type: 240-pin DIMM
Black PCB
Warranty: Lifetime
ORDER NOW
Samsung Green 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit (MV-3V4G3D/US) @ £47.99 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.<br/><br/>
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB). <br/><br/>
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<br/><br/>
<strong>Features:-</strong><br/><br/>
- Model Name: MV-3V4G3D/US<br/>
- Main Board: INTEL/AMD<br/>
- System: DESKTOP/SFF<br/>
- System Type: DDR3<br/>
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets<br/>
- CAS Latency: 11-11-11-28 1N<br/>
- Capacity: 8GB (4GBx2)<br/>
- Speed: DDR3-1600 (PC3-12800)<br/>
- Test Voltage: 1.25-1.55V<br/>
- Registered/Unbuffered: Unbuffered<br/>
- Error Checking: Non-ECC<br/>
- Type: 240-pin DIMM Low Profile<br/>
- Warranty: Lifetime<br/>
<br/><br/>
<strong>
Overclocking Features (Not Guaranteed)</strong><br/><br/>
- 1600MHz (7-8-8-24 1N) @ 1.40v<br/>
- 1866MHz (9-9-9-27 1N) @ 1.40v<br/>
- 2000MHz (9-10-10-28 1N) @ 1.45v<br/>
- 2133MHz (10-10-10-28 1N) @ 1.45v<br/>
- 2400MHz (11-11-11-28 2N) @ 1.50v<br/>
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M<br/>
ORDER NOW
One of the major improvements with Ivybridge and Z77 is memory overclocking potential, its far better. Which means our exclusive Samsung Green memory is an ideal candidate in both 8GB and 16GB Kits.
Features:-
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Fan lncluded: No
ORDER NOW
Features:-
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Fan lncluded: No
ORDER NOW
Features:-
- 1866MHz
- 9-10-9-27 latency
ORDER NOW
Features:-
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Fan lncluded: No
ORDER NOW
Features:-
- Series: TridentX
- System: DESKTOP
- System Type: DDR3
- Main Board: INTEL
- M/B Chipset: Z77
- Fan lncluded: No
ORDER NOW
Features:-
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
ORDER NOW
Specifications:-
- XMP Profile: 1.3
- System: Desktop
- System Type: DDR3
ORDER NOW
Features:-
- Main Board: INTEL
- System: DESKTOP
- System Type: DDR3
- Black PCB
ORDER NOW
Features
- 8GB Modules
- Lifetime Warranty
ORDER NOW
- Airflow Fan
- Speed: 2133MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
ORDER NOW
- Lifetime Warranty
ORDER NOW
- Black PCB
- Lifetime Warranty
ORDER NOW
Specifications:-
- XMP Profile: 1.3
- System: Desktop
- System Type: DDR3
ORDER NOW
- 1600MHz
- 9-9-9-24 latency
- Voltage: 1.35V
ORDER NOW
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Type: 240-pin DIMM
Warranty: Lifetime
ORDER NOW
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Type: 240-pin DIMM
Black PCB
Warranty: Lifetime
ORDER NOW
nonl2br
<br/><br/>
<br/><br/>
<strong>
ORDER NOW
