Jack Daniel's - #OnTheRocks
Amazing work. It's probably been mentioned here as I haven't read all the comments... but it would be pretty cool if you used a bottle of JD as a reservoir.
Some large updates.
Over the weekend, i finished the loop, ran a leak test and ran into several issues.
Majority was recorded, and because of the leaks that happened, i just trashed the video.
So looks like i'm skipping the build video and just moving to final images + Videos.
At this moment in time, it's just touch ups here and there that are required, cables to moved around inside etc.
Anyway, here's a couple shots from last night and a live video of the build that was done on facebook last night.
Video:
Thank you for looking
More to follow soon
Craig
I hadn't popped in a for a while so missed a large bulk of updates (you don't muck about) - but just, brilliant!!
The open design front and back works really well thanks to your coraldraw/autolaser fabrications and your tubing/routing. As mentioned earlier, the attention to detail is amazing and has really made this build a work of art.
From concept to finished product it's a great build log with superb results.
*I imagine your sponsors will be very happy!
This made my day, thank you for your kind words. Things like this spur my mind to do more, to do better. Thank you
Absolutely stunning, great job. Very impressive pictures too. Nice too see it all running.
It's kind of relaxing watching the liquid being poured in the video :).
Thank you :) You should try sitting next to the system, after a cuppa coffee... I feel like i need to book in a prostate exam i'm peeing so often lol.
Figured i should do a run down of overall cost to build + full part list and valuation.
Some people like to see these numbers.
Wooden slats = FREE (Was taken from my old double bed frame which i was tossing out anyway) Est value - £40
Framework wood = FREE (Was leftovers from when i built a bench in one of our home's window bays) Est value - £20
Wooden sheets to do top, mid and bottom of case = 20p per sheet, so about £3
Etchings = FREE (my own laser and my own designs)
From sponsors - Estimated value
Glass bottle = £5
Tumblers = £10
Bar mat = £5
ASUS ROG UK Parts
ASUS ROG Strix X570-E Gaming Motherboard = £270
ASUS ROG Strix RTX2080 OC Edition = £700 in todays current market. (Likely to change dramatically soon)
XPG Parts
MEMORY: XPG Spectrix D60G DDR4 16GB @3200mhz = £90
SSD: XPG Spectrix D40G M.2 SSD 512GB £80
Cablemod
Cablemod: Custom made to order cables. = £110
AMD
CPU: AMD Ryzen 3800X = £280
EK Waterblocks cooling list
EK-CPU Lignum - Walnut
EK-Quantum Vector Strix RTX 2080 D-RGB - Nickel + Acetal
EK-Vector Strix RTX 2080 Backplate - Black
EK-HTC Lignum 10/12mm - Walnut
EK-CoolStream Classic PE 360
EK-Quantum Inertia D5 PWM D-RGB - Acetal
EK-AF Classic Angled 90° - Black
EK-AF Classic Angled 45° - Black
EK-CryoFuel Clear (Premix 1000mL)
EK-AF Extender 6mm M-M G1/4 - Black
EK-AF ALU T-splitter 3F G1/4 - Natural Grey
EK-CryoFuel Dye Pack
EK-HD PETG Tube 10/12mm 500mm = Total £1,200
Extras
Cooler Master: MasterFan SF360R ARGB 360mm £30
Riser cable = £60
No return valves = £15
Soft tubing for valves £5
Total value £2,923
Will have final photo's coming this weekend.
<3
Uploaded some final images.
Was a nice day today, figured i'd get in some shots.
Will upload more detailed shots over the weekend.
Thanks for looking
Craig
#ontherocks is finally finished!
What an incredible journey it has been.
Would like to thank our partners
EK Water Blocks
CableMod
XPG Global
ASUS Republic of Gamers
AMD Gaming
Jack Daniel's Tennessee Whiskey
Without them, this project would NEVER have been possible.
System Specs:
EK-CPU Block Lignum - Walnut
EK-HTC Lignum 10/12mm Fittings - Walnut
Be quiet! (English)
Dark Power pro 11 power supply
Extras
Cooler Master
Premium Riser cable
No return valves (Under shroud)
Soft tubing for valves (under shroud)
Custom 15cm USB Extensions
Custom Kettle plug Extension
22 wooden slats
12 A4 size birchwood sheets
Jack Daniel's Bar mat
Jack Daniel's Tumblers
Jack Daniel's 1L Whiskey Bottles
The system has 2 reservoirs that are interchangable.
One = Closed loop, no evaporation or dust.
Two = Open loop, water falls from bottle to glass. (for show event use)
Thank you to everyone who viewed, commented and shared the project.
If you'd like to follow all future updates (shows/events or what happens next) check out https://www.facebook.com/MTMods
Thank you again.
<3
