Jack Splitter Help Please
18 Jan 2012
Hi
Just bought some of them snazzy G9000's but only getting sound and no MIC,
Done a bot of googling and come to realise that jack is either input, output, or both input and output.,.
So my green jack at rear is output only, yer?
And I have 2 jack at top of my case one for MIC and one for headphone.. I only get sound from the headphones and no MIC,
So I need jack splitters but do I need certain ones for a gaming headset or will any jack splitter do what I need..
cheers for your help,
You need to work out what the jacks on your device are, then get the appropriate adapter/s. A common arrangement is a 4-pole jack plug where the tip and first ring are audio left and right (standard headphone arrangement) then the second, additional ring, is the mic.
A bit of research should help but if it's a stereo headset with mono mic, my money is on that arrangement. Try searching online for "G9000 pinout"
