Jade or Zen
19 Jul 2006
Hi,
Just wondered if anyone used Jade for making websites, not web apps just static sites?
Is it made to cut down on like zen coding (emmit?) or have i got it wrong?
Also is it a case of making a jade file then running it through the processor and using the output html as the production version or do you use the jade file?
Cheers
I use it for most of my projects, though not for static content and I've only ever used it with the Express template engine.
The way it's used with Express is it's run through the template engine which parses the jade in real-time and sends the rendered output from the server to the client.
If you're wanting to use it with static content then I can't see it being worth your time.
