The standard reply is that if you can afford to run a car like this then you can afford to spend more on a car. So you should ever only really buy a car like this if your an enthusiast.
Or the more blunt version... you can't afford to run one.
Following on from this a good alternative usually is a Mondeo.
Lol at the standard motors reply
Would this apply to anybody wanting a proper performance / luxury car for under 10 grand ?
Obviously if you cant afford a 2 year old or newer super saloon you should never ever consider buying an older one as every single one of them will surely bankrupt you
I've gone through a succession of cars recently, a Lexus IS250, Volvo S60 T5 and currently a '03 Lexus GS300, all of which have had there good points (the IS250 being the best) and bad points, but I want to find something special that I'll keep for more than 8-9 months!
What is it you don't find special enough about the '03 GS300? just thinking because f you like the car but want more power just get the twin turbo version.
If you want a XJR X308 then get an XJR X308, dont let these lot put you off and for £5k Im sure with a bit of shopping you could get yourself and nice reliable example.
Not bad for what in its day used to be one of the fastest production cars in the world
[TW]Fox;22266269 said:That said you've been exceptionally lucky for any car, let alone an XJR. Heck I wouldnt even fancy a wager that you could run a Ford Focus for 5 years with that little going wrong! Though some of your numbers are bit misleading, 14 quid for a bush, fit itself for free did it, and you've neglected to mention the fact it does teen mpg around town etc
Not even close. Perhaps true if you limited it to 4 door saloons, but it wasn't ever one of the fastest production cars in the world!
[TW]Fox;22266476 said:I wish I could do bushes on mine for 14 quid![]()
