Java and SSL Sockets help
Man of Honour
11 Dec 2002
Darkest Norfolk
Hey guys, i'm wondering if anyones any good with jsse and can give me an hour or two of there time (I don't mind re-embursing at a reasonable rate) to help sorting out some problems i'm having creating a client to connect to an existing apachi server :)
Cheers
Sam
edit: i'll add some more info -
Basically its a SOAP server that takes in messages, i have it all working over http and https however i'm trying to get a SSL connection to it working.
I have the cert for the server in the security container (/lib/security) of the jre and i'm using the following code to form the connection:
Code:
InetAddress addr = InetAddress.getByName(hostname);
            SSLSocketFactory sslsocketfactory = (SSLSocketFactory) SSLSocketFactory.getDefault();
            [b]SSLSocket socket = (SSLSocket) sslsocketfactory.createSocket(addr, port);[/b]
            socket.setSoTimeout(120000);
            String path = "/servlet/SomeServlet";
            BufferedWriter wr = new BufferedWriter(new OutputStreamWriter(socket.getOutputStream(), "UTF8"));
and i just keep getting the following error
Code:
java.net.ConnectException: Connection timed out: connect
	at java.net.PlainSocketImpl.socketConnect(Native Method)
	at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:305)
	at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:171)
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:158)
	at java.net.Socket.connect(Socket.java:452)
	at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect(DashoA6275)
	at com.sun.net.ssl.internal.ssl.SSLSocketImpl.<init>(DashoA6275)
	at com.sun.net.ssl.internal.ssl.SSLSocketFactoryImpl.createSocket(DashoA6275)
	at com.cogent.SOAP.SoapSend.runReqT(SoapSend.java:197)
	at com.cogent.SOAP.SoapSend.run(SoapSend.java:49)
(197 is the bolded line)
