Java Exception Help
27 Aug 2004
Geordieland
Hi guys,
Im having a spot of bother with a bit of exception handling ive got to do for uni, is it possible for someone to give me a bit of advise on where im going wrong please.
Driver Class
Code:
public class ExceptionHomeworkDriver
	public static void main ( String [] args)
	     ExceptionHomework exHmwk = new  ExceptionHomework();
	     exHmwk.Data();
	     System.out.println("Good Bye");
Code:
    Scanner scan ;
    int data;
    int slot;
    int[] value;
    public ExceptionHomework()
        scan = new Scanner( System.in );
        data=0;
        slot=0 ;
        value = new int[10];
    public void Data()
    	do
    		try
      			System.out.print("Enter the data: ");
      			data = scan.nextInt();
      			System.out.print("Enter the array index: ");
      			slot = scan.nextInt();
      			value[slot] = data;
      		catch (NumberFormatException nfe)
		 		System.out.println("Exception "+nfe.toString()+ " caught\n");
		while(!done);
This is the error im getting
Code:
D:\Uni\Semester 2\Java\Hmwk8\Homework8\ExceptionHomework.java:50: cannot find symbol
symbol  : variable done
		while(!done);
Any help/advice greatly appreciated.
hi,
I think your problem is that the while(!done) part is inside your do loop. If memory serves it should look like this:
do
//some stuff
}while(!done)
but you have this:
do
//some stuff
while(!done);
Yeah, 'done' should be a boolean variable defined somewhere in your class. It should be set to true somewhere in the do...while loop to cause an exit condition.
